Abse - @Seve https://github.com/tscircuit/check...
mention https://github.com/tscircuit/check shorts/actions/runs/29109528717/job/86424789636
Started by AbseJul 10, 202616 messages
Abseoriginal post
<@757706909351411845> https://github.com/tscircuit/check-shorts/actions/runs/29109528717/job/86424789636
<@757706909351411845> https://github.com/tscircuit/circuit-json-routing-analysis/pull/5
<@757706909351411845> https://github.com/tscircuit/kicad-to-circuit-json/pull/165/changes
merged this
<@757706909351411845> after updating tscircuit package this test is passing with no errors is this right ? https://github.com/tscircuit/cli/pull/3623/changes#diff-16b557c6b4630cd68342d4b5fb5e66c655631e27983906eac07a0e8157bc0165
No obvious issues with that as far as I can tell
https://github.com/tscircuit/cli/pull/3638
updated circuit json to gerber and had to add polygon-clipping to dev deps
sg
yea someone introduced that recently
i'm making the @tscircuit/manifold-2d still, hopefully we can start to fix things once that dep is rock solid
https://github.com/tscircuit/manifold-2d
<@757706909351411845> https://github.com/tscircuit/cli/pull/3647
<@757706909351411845> https://github.com/tscircuit/check-shorts/pull/25
