Anas - Could I get everyone’s opinion on this?...
Could I get everyone’s opinion on this? I added several Board Surface Texture options so we can compare them and choose the best looking one. To test: 1. Make sure Realistic Presentation Mode is enabled. 2. Right click the viewer. 3. Open Board Surface Texture and try the options
Started by AnasJul 9, 202638 messages
Anasoriginal post
Could I get everyone’s opinion on this? I added several `Board Surface Texture` options so we can compare them and choose the best-looking one. To test: 1. Make sure `Realistic Presentation Mode` is enabled. 2. Right-click the viewer. 3. Open `Board Surface Texture` and try the options. Preview: https://3d-viewer-71maic27u-tscircuit.vercel.app/?path=/story/keypad--default
I like it does it also have the light map/ normal map?
Looks 🔥
Do you have any less aggressive texture need to see some variations pcb are quit smooth I think, but we pick whatever looks best
I think there are two smooth texture did u check them?
These textures look good, but could have performance issue.
The backgound seems too dark, kicad 3d viewer doesn't have this kind of dark background. What are you referencing?
That's why we chose to make it an option in the right-click menu
Ivory looks right to me
I'm between Ivory and Paint Substance 001
New update to use generic component material profiles https://3d-viewer-71maic27u-tscircuit.vercel.app/?path=/story/keypad--default
The metal components look good but most components are plastic not metal
The waviness isn’t a good fit imo
Oh i can change it
there are many but I think all of them having this shit
we need a way to reduce light refliction on board texture
You might want to adjust the board surface magnitude in a right click menu
Yea
That is the “roughness” or something
Getting closer
I didnt go through them all but concrete wasnt too bad imo
The right click menu barely works on mobile (unrelated issue)
I create new board texture plz check https://3d-viewer-ufk0g21rv-tscircuit.vercel.app/?path=/story/keypad--default <@757706909351411845>
<@400684445054795796>
now more reflection/waves
the keys look super metally
updated board texture
<@757706909351411845> <@400684445054795796> 👀
I like it, don't you think the white background is better?
looks cool
yea looking pretty good, i'm still not fully satisified with the board texture (i want a tiny bit of grain or something) but it is pretty good
https://3d-viewer-ly0h50unk-tscircuit.vercel.app/?path=/story/keypad--stm-32-f-746-g-disco
<@757706909351411845> check this
