mohan-bee - Anyone can help me with a solution...
Anyone can help me with a solution for this issue , "edge cutouts are being emitted as separate" That is fine for cutouts fully inside the board, but wrong when the cutout touches the board edge. A circle on the edge becomes a full circle in Gerber, so the outside half makes the
Started by mohan-beeJul 7, 20268 messages
Anyone can help me with a solution for this issue , "edge cutouts are being emitted as separate" That is fine for cutouts fully inside the board, but wrong when the cutout touches the board edge. A circle on the edge becomes a full circle in Gerber, so the outside half makes the board look bigger. https://github.com/tscircuit/circuit-json-to-gerber/pull/118
i would work w/ ai on this- in particular try to get a version of the GERBER that renders properly- don't worry about the implementation- then afterwards figure out how to generate the gerber properly
<@757706909351411845> what do you think about using this package, "https://github.com/mfogel/polygon-clipping" To fix the cutout in kicad, we need to subtract the cutout shapes from the board outline,.. turning them into one clean, unified outline.. but this is actually doing. a great job: check this PR: https://github.com/tscircuit/circuit-json-to-kicad/pull/365 maybe this can help in gerber too ig .
why not use flattenjs, is this one smaller
<@757706909351411845> actually this one is having much smaller bundle size, idk is this a right way to confirm , https://bundlephobia.com/package/polygon-clipping@0.15.7 https://bundlephobia.com/package/@flatten-js/core@1.6.12
Sapphire
Its fine- we just already bundle and use flattenjs, but i think its fine to use polygon clipping
