Anas - text (s letter) in 3d image looks very b...
text (s letter) in 3d image looks very bad.
Started by AnasJul 2, 202619 messages
<@757706909351411845> Im not sure what we should do to show users for how to generate QR code svgs. I found this: ```tsx import QRCode from "qrcode" const docsQrSvg = await QRCode.toString("https://tscircuit.com", { type: "svg" }, }) const docsQrUrl = "data:image/svg+xml," + encodeURIComponent(docsQrSvg) export default () => ( <board width="32mm" height="24mm"> <silkscreentext text="tscircuit.com" pcbX={0} pcbY={-8} fontSize="1.2mm" layer="top" /> <silkscreengraphic imageUrl={docsQrUrl} pcbX={0} pcbY={1} width="14mm" height="14mm" layer="top" /> </board> )```
Yep
That works
You will need to make sure the svg server has that dep
I used `qrcode-svg` instead of the `QRCode` package because it produces much better QR code visualization. Since `qrcode-svg` is CommonJS and does not ship TypeScript declarations, I added a small local type in the eval module shim. PR: https://github.com/tscircuit/svg.tscircuit.com/pull/1720
Awesome
We can publish a @tscircuit/qr-code package that exports a component directly soon imo
That is even better/simpler i think
amazing
btw the qr code stroke widths look a bit too big imo
i think it's interpreting the aliased strokes incorrectly
this is a core/image-utils rasterization issue
Is this ok to merge the docs PR and do the silkscreen fix later? CC: <@809856037376491570> https://github.com/tscircuit/docs/pull/773
<@756504518417711104> You have mentioned a package, maybe add another option something like - https://www.qrcode-monkey.com You can paste the link which you want to convert qr code of, and then use that svg
Also I think I should add our qr code generator repo `@tscircuit/qr-code`
lgtm! <@757706909351411845> Is it okay to have links of other website on our docs like the qrmonkey?
