Seve - @Abse in addition to shorts we can use t...
mention in addition to shorts we can use the same bitmap technique to detect things not connected in fact we might want to call it bitmap probe
Started by SeveJul 1, 202631 messages
<@398467566588264449> in addition to shorts we can use the same bitmap technique to detect things not connected- in fact we might want to call it bitmap-probe
<@757706909351411845> https://github.com/tscircuit/core/pull/2549
heading to bed , let me know if this is ok for a fix ?
do we know this doesn't create the same issue as Rishabh's fix?
I generated the Srj from my Gameboy circuit Json and routed it using welcome page on the autorouter
Routed in 34 sec
I think it's safe hopefully
oh
ok
i suspect it didn't connect the subcircuit
idk if you can easily verify that
idk worth a try i suppose
i'm trying to understand what's happening with the subcircuit logic
I can check tomorrow
ok- maybe we can merge to make it easier, the subcircuit logic is not clear
idk
i think it should be rewritten to be clear
i will take a look
Ok sg ty
yea it's not right
i'm glad we didn't merge
it actually disables a lot of DRC
Rishabh also did the same- we really can't merge PRs like this- some of the bugs being introduced would have been annoying
e.g. it allows traces to share the same name
(because it was trying to fix something unrelated)
i literally just asked the ai to go through and comment to explain each thing and i was like "oh wow, that's wrong"
Nice catch sry I just did a quick pr before sleeping, you got a better fix?
i'm just going through it step by step
yea i will try
Ok gn
yep night!
