Richard - This is likely pretty basic, but how ...
This is likely pretty basic, but how are connections meant to be made between components. I see I can specify connections in the connection prop on an element or by using the trace element. Are these equivalent?
Started by RichardJun 26, 20263 messages
Richardoriginal post
This is likely pretty basic, but how are connections meant to be made between components. I see I can specify connections in the `connection` prop on an element or by using the `trace` element. Are these equivalent?
yea equivalent. in some cases, you can specify additional properties like maxLength using <trace />
I would suggest using <trace/> as you can have extra properties with it
