Mustafa7 - @shibo https://github.com/tscircuit/...
mention https://github.com/tscircuit/eval/actions/runs/27974473928/job/82788627726?pr=2995 https://github.com/tscircuit/eval/pull/2995
Started by Mustafa7Jun 23, 202610 messages
Mustafa7original post
<@778624824875941908> https://github.com/tscircuit/eval/actions/runs/27974473928/job/82788627726?pr=2995 https://github.com/tscircuit/eval/pull/2995
I am not sure this is correct fix but yesterday i did confirm from shibo, looks good for him
I'm not sure about the font issue, but the test changes are ok
Fonts are changing due to kicad fix i think
Font's are changing cause the kicad-mod-cache repo has been migrated from `kicad-component-converter` to `kicad-to-circuit-json`
<@809856037376491570> can this be merged: https://github.com/tscircuit/eval/pull/2995
please review
https://discord.com/channels/1233487248129921135/1515328809979740281/1518848791195815936 The font doesn't look like a 1.5 times in the change <@398467566588264449>
foobar
I independently arrived at similar fixes from 2995 in this pr: https://github.com/tscircuit/eval/pull/2999 (I didn't notice this thread or that 2995 had additional files in the PR) - it looks like 2995 was closed by the bot, this pr unbundles the bot's changes to package.json and only fixes the test bugs, with a comprehensive ai explanation of what happened. One difference I should mention between 2999 and 2995 is 2995 actually removed the cdn fetch for the eecircuit bundle and uses a local test fixture, which changed the test behavior from live-cdn test. Mine continues to fetch from the live cdn (I actually think remote server tests during CI is incorrect behavior but opted not to change it without further discussion). I know you all are really busy right now so hope this pr and summary is helpful.
