shibo - @Seve @Rishabh I was able to run the si...
mention mention I was able to run the simulation in the cli in the ti repo succressfully, however in the dev server runframe is bundling an old version of circuit to svg, do you have any idea about this issue? I tried to update circuit to svg in runframe but it's still using an o
Started by shiboJun 20, 202620 messages
<@757706909351411845> <@809856037376491570> I was able to run the simulation in the cli in the ti repo succressfully, however in the dev server runframe is bundling an old version of circuit-to-svg, do you have any idea about this issue? I tried to update circuit-to-svg in runframe but it's still using an old version
You mean the schematic-viewer is using the old version?
the schematic-viewer will use whatever version is in runframe. runframe is bundling an old version of circuit-to-svg
looks like there is a version conflict
<@809856037376491570> pcb-viewer is a culprit: https://github.com/tscircuit/pcb-viewer/pull/905
<@809856037376491570> can you please see why the deployment if failing: https://github.com/tscircuit/runframe/pull/3738
@here https://github.com/tscircuit/ngspice-spice-engine/pull/22
finally worked in the dev server, the graph looks squashed though
Niceee
<@436098556974333952> <@1079361271687807026> i would love to show this to our partners but concerned about the schematic- doesnt look good- can we fix? <@778624824875941908> you should use displayName for the traces and try to get it a bit better
still missing the current graph, and the I want to investigate why it's squashed, I'll push the circuit so someone else can check the schematic
https://github.com/tscircuit/schematic-viewer/pull/229
<@757706909351411845> https://github.com/tscircuit/circuit-to-svg/pull/580 https://github.com/tscircuit/props/pull/699
<@757706909351411845> new spec: https://github.com/tscircuit/circuit-json/pull/614
Is this manually placed?
yeah like all other circuits in the ti library repo
We are improving the auto-placed schematic. You can use the `schMaxTraceDistance` that will get rid of fallback netlabels. Regardless can you share me the circuit
