Richard - I saw that you can order PCBs directl...
I saw that you can order PCBs directly from you guys. I'm curious do you have design guidelines for your process? e.g. minimum spacing, how many layers (I assume two?), and do you do electroplating for the vias?
Started by RichardJun 19, 20268 messages
Richardoriginal post
We are just launching the process! Yea we should prep a pdf <@809856037376491570> <@436098556974333952> We only support “credit card sized” 2 layer pcbs right now- our goal is $5 with free shipping to the US
We dont electroplate, but we ship with via rivets you can manually insert
Richard
Brilliant, looking forward to trying it out
Richard
Will there be a soldermask/silkscreen applied?
Most likely! We have a new machine for it but may not launch in time- its actually a interesting week or two for us because we’re moving to a new factory space from an office spce
Richard
Sounds like an exciting time for you all! I’ll wait a little bit then. I’ve been milling my own PCBs, but I’ve been missing having a proper solder mask, so that would be a big plus for me.
Yea we can quickly make them with a laser the only issues is actually applying the mask, we just got a hot press for dry laminate so im hoping that makes it easy
