Anas - @techmannih @mohan-bee @! Rushabh | Linu...
mention mention mention please anyone can fix this
Started by AnasJun 19, 202627 messages
I see this issue after updating schematic-symbols in core
will take a look
For an NPN transistor, the pin numbering depends on the specific transistor model and package. There is no universal pin order.
What should we follow <@1067854999889137715>
1 = Emitter, 2 = Base, 3 = Collector seems to be the most commonly used
<@756504518417711104>
yeah thats what core/props follow
So make sure schematic-symbols are following same pattern
core follow different pattern ```ts initPorts() { const pinAliases = { pin1: ["collector", "c"], pin2: ["emitter", "e"], pin3: ["base", "b"], } ```
maybe we need to update core to match with props. also symbols they are mapped incorrectly. pin1: emitter, pin2: collector, pin3: base.
schematic-symbols and core both need to be changed ig
https://github.com/tscircuit/schematic-symbols/pull/429
we follow this rn for npn but not pnp
we can just fix pnp to follow the same ig currently pnp
https://github.com/tscircuit/schematic-symbols/pull/430
now we need to fix the same in core
https://github.com/tscircuit/props/pull/698
<@452450065941004289>, make sure you get a review from Rishabh or Seve. Previously We got stuck on this once before and that creates a lot of issues iirc
the updated schematic-symbol aligne with this image
in order to update the core we need to update to props first
https://github.com/tscircuit/props/pull/698 <@809856037376491570> can you take a look
