Rishabh - @shibo Can you look at why test is fa...
mention Can you look at why test is failing? The simulation test is failing https://github.com/tscircuit/svg.tscircuit.com/actions/runs/27755327962/job/82115618633?pr=1611
Started by RishabhJun 18, 20262 messages
Rishabhoriginal post
<@778624824875941908> Can you look at why test is failing? The simulation test is failing https://github.com/tscircuit/svg.tscircuit.com/actions/runs/27755327962/job/82115618633?pr=1611
you may need "@tscircuit/eecircuit-engine": "https://jscdn.tscircuit.com/@tscircuit/eecircuit-engine/1.7.4.tgz", as a dev dep, I'm afk rn, I can check in 30-60mins
