Anas - @! Rushabh | Linux Shill please take a l...
mention please take a look I’m adding <ammeter / in core and found issue, schematic symbols has dc ammeter horz correctly defined with the A inside the circle, but when core renders the schematic SVG through circuit to svg, that literal A text gets dropped. The SVG ends up showin
Started by AnasJun 18, 202617 messages
Anasoriginal post
<@452450065941004289> please take a look I’m adding `<ammeter /> ` in core and found issue, schematic-symbols has dc_ammeter_horz correctly defined with the A inside the circle, but when core renders the schematic SVG through circuit-to-svg, that literal A text gets dropped. The SVG ends up showing the circle and meter line, but the center A is blank.
Looks like circuit-to-svg only handles {REF} and {VAL} text inside schematic symbols, and any other literal symbol text becomes empty. I’ll attach screenshots showing the symbol site vs the rendered core output.
or anyone
cc:<@1238122660345548882> <@1067854999889137715>
we need an AC ammeter too
TI circuits are analog
forgot the AC for now, just fix the issue that I mentioned above
doing the fix.
maybe u can write the "A" letter with svg path same as the voltameter do
https://github.com/tscircuit/circuit-to-svg/pull/577 <@756504518417711104>
<@756504518417711104> also i tried to convert the text into path in the schematic symbols , you can take a look.
sg just lmme know if u fixed it
or mention me to review
https://github.com/tscircuit/schematic-symbols/pull/428 <@756504518417711104>
was afk
<@756504518417711104> fixed in schematic symbols do we have to update the package anywhere apart from core ??
perfect, updated
