Techmannih - Screenshotfrom2026-06-1217-10-57.p...
we have a cad model issue for footprint="kicad:..." The imported CAD model is much larger than the footprint landed pads. Are all CAD models showing up as white !!! CC mention . This seems like a big regression KiCad models may need to be converted to mm they may be in inches bec
Started by techmannihJun 12, 202633 messages
CC <@398467566588264449> . This seems like a big regression
KiCad models may need to be converted to mm- they may be in inches because the resize factor looks like 2.56x or something
in which repo i need to add the repro for this
I have tested it in core, and it works well there.
Hmm not sure this is strange, try eval
yep gets a regression in the eval
The bug in eval was that the KiCad loader incorrectly applied a (modelUnitToMmScale) 2.54x scale to the STEP CAD model,
Nice find lets add a regression test
yea on it
Can you check it https://github.com/tscircuit/eval/pull/2905
<@757706909351411845> <@398467566588264449> I have fixed the scaling issue, now we have the position offset issue for pinrow/pinheader for kicad cad models
maybe check if the cad model pos relative to the pin1 or the center of the fp
<@398467566588264449> I found the issue in circuit-json-to-gltf: when center_of_component_on_board_surface is used, the CAD model origin is inferred incorrectly.
getMeshOrigin() returns { x: 0, y: 0, z: 0 } directly when no explicit model_origin_position is provided
Can you take a look https://github.com/tscircuit/circuit-json-to-gltf/pull/166
<@398467566588264449> can you take a look https://github.com/tscircuit/circuit-json-to-gltf/pull/167
hey u back home ?
I think it lg , can u double check when u have free time
Im back!!!!
Wow welcome back!!! after 2 weeks 🫡
<@398467566588264449> the kicad library cad model are white bcoz the 3d-viewer STEP pipeline was ignoring brep_faces color data from occt-import-js and collapsing the STEP mesh into a single material.
can you take a look https://github.com/tscircuit/3d-viewer/pull/943
<@757706909351411845> <@398467566588264449> https://github.com/tscircuit/3d-viewer/pull/945
can u give me the repro link in the preview
Ohh sorry
Updated
nice work
