Techmannih - We should use fast-xml-parser to p...
We should use fast xml parser to parse the imported SVG image so we can extract its shapes, transforms, and fill rules, convert them into paths/polygons, and then generate internal BRep pcb silkscreen graphic geometry.
Started by techmannihJun 12, 202614 messages
We should use fast-xml-parser to parse the imported SVG image so we can extract its shapes, transforms, and fill rules, convert them into paths/polygons, and then generate internal BRep pcb_silkscreen_graphic geometry.
does the sound right?
KEV0
I concur
I think itd be easier/more universal to use an image analysis and convert to a bitmap internally for silkscreen graphics
Unfortunately requires loading an svg to png converter- but we have one iirc <@809856037376491570>
Like tscircuit/image-utils (?)
KEV0
Does tsciruit already support bitmap by default?
We dont have any support for loading graphics afaik
Not directly in our core lib
So this is our first brush with image filters but we render svgs to pngs for lots of stuff outside the core lib
KEV0
Ah I see. I had to make a workaround for my previous PCB build. I wanted to add some icons to the board as part of the aesthetic but since there was no image support the agent tried to rebuild the SVG from scratch to fit what was possible and it did a terrible job. Until I went into Inkscape, recreated the icon as paths. It did not have any issues from there recreating it.
Yep, goal is to add image support and direct image import
Should make that wayy easier
<@757706909351411845> <@809856037376491570> Can we directly add image import in the core repo? Something like: SVG/Image Import → internally convert to bitmap/PNG → generate silkscreen graphics
