Seve - @Techmannih 1206x4 has a 3d model in kic...
mention 1206x4 has a 3d model in kicad that is pretty good, can possibly be used as reference My 1206x4 footprint does not match kicad's, here's the datasheet for it https://industrial.panasonic.com/cdbs/www data/pdf/AOC0000/AOC0000C14.pdf I have no idea why it doesn't match kica
Started by SeveJan 13, 202633 messages
<@1067854999889137715> 1206x4 has a 3d model in kicad that is pretty good, can possibly be used as reference My 1206x4 footprint does not match kicad's, here's the datasheet for it https://industrial.panasonic.com/cdbs/www-data/pdf/AOC0000/AOC0000C14.pdf I have no idea why it doesn't match kicads but maybe you can figure it out
Okay I will check it again but we have already matched this kicad parity test.
i confirmed it physically, kicad has the wrong footprint for my chip
if we need to create parameters that's fine (e.g. width, height)
if width/height are provided we need to compute pitch
this is what i bought https://www.digikey.com/en/products/detail/panasonic-electronic-components/EXB-38VR000V/417359
i think 3216 metric might be a clue, because the body dimensions are 3.2mm by 1.6mm
but honestly from what i'm seeing kicad is just wrong
Oh
i've gone through a ton of jumpers and they are all 3.2mm x 1.6mm
I will match with https://industrial.panasonic.com/cdbs/www-data/pdf/AOC0000/AOC0000C14.pdf
Mostly we use pinrow for jumpers?
a resistor array with 0ohms IS a jumper
Okay
<@1067854999889137715> https://tscircuit.com/seveibar/1206x4_3216metric#files
^ this looks like it's probably correct
i'll test it on the laser in a sec
https://github.com/tscircuit/jscad-electronics/pull/251
The footprint i linked above
is it correct now?
the one i made is correct yes
<@757706909351411845> can you check it https://github.com/tscircuit/docs/pull/764
<@757706909351411845> The chips we currently have in `tscircuit/ti` are also imported from JLCPCB. Can we add those chips to the documentation as well? They're currently used by their MPNs. For example, `BQ24074` is exported as `BQ24074RGTR`.
Yea all the chips need to be individually listed in the README but not the docs. The docs just need an overview and link to the README
as for the naming, the short name with a footprintVariant prop to change between different available footprints is the best option
This means you will need to import from jlcpcb multiple times for a single chip
This is a really great idea! I was concerned about which footprint we should use, especially since the datasheet often provides multiple footprint options for the same chip. This approach makes it much clearer.
<@757706909351411845> I think we should use the TI chips like this. Does that sound right? ``` import { BQ24074 } from "@tsci/tscircuit.ti" export default () => ( <board width="14mm" height="14mm"> <BQ24074 name="U1" footprintVariant="rgtr" pcbX={0} pcbY={0} /> </board> ) ``` https://github.com/tscircuit/ti/pull/46
Sapphire
YES!!
BUT rgtr is not a readable footprintVariant! Try to find a better name (not the codename ideally!)
